2005 RAM 2500 4x4 5.9l - where to grease Front Prop Shaft exactly?
Old Nov 28, 2023 | 07:54 PM
riderboy1961's Avatar
riderboy1961
Default 2005 RAM 2500 4x4 5.9l - where to grease Front Prop Shaft exactly?
Good Afternoon;
I have a: 2005 RAM 2500 4x4 5.9l
I have the owners manual - pg. 358 has a picture of where the service spot ought to be - I looked all over the Prop Shaft and both u-joints that are in there and I could Not find neither Zirk fitting nor a Flush Mount Zirk that we would use a grease Needle to service with.
Anyone happen to have a picture of an actual zirk fitting on their front drive shaft Prop Shaft?
Thank You
Old Nov 29, 2023 | 07:25 AM
There may not be any zerk fittings, of any description. If the joints have been replaced... they may be the 'sealed' units, that never had a zerk.
Old Nov 29, 2023 | 09:26 AM
riderboy1961
See Attached Picture- This is what my owners manual reads: My interpretation is that it is somewhere on the Prop Shaft as it reads in the owners manual. I do not believe they mean a u-joint or it would read u-joint.?
Old Nov 29, 2023 | 02:45 PM
Yeah, that's on the CV joint. Might be for the ball coupler in the middle there, if you can't find it, don't worry about it.
