Replacing 4x4 dashboard light?
Old Dec 2, 2023 | 09:04 PM
ABlo22's Avatar
ABlo22
Default Replacing 4x4 dashboard light?
I have a 2005 ram 1500 5.7 hemi with a manual floor shifter for 4wheel drive. Ever since I have had it the 4WD light has never come on on the dashboard even when engaged. The 4WD works perfectly in every mode. I ran a C Code test on the dashboard and every light lit up except for the SERV 4WD light which leads me to think is the light is burnt out instead of the more common sensor issue. Is there a specific bulb for that light and if so what is it? Is it even possible to replace or do I have to replace the whole dashboard? Thanks!
Old Dec 3, 2023 | 08:34 AM
William Scott's Avatar
William Scott
if you have some experience with Electric components you go for DIY ! if not a professional must do the job
