2005 Daytona 5.7 PO300 PO132 Gremlins
Hello there,"question the po132 code showed changed the o2 sensor code did not stay off for long.Last night the engine light started to flash.I stopped right away.Cheched the oil was low 1 quart after 1 week oil change plus moisture in cap i noticed?After restarting the engine light stopped flashing went solid.When home checked now both these codes showing.Not sure where to start?Any input would be very much appreciated.The o2 sensor that i changed was 1/1 circuit high.The po 300 code clears but returns as soon as warm.
Did you install it yourself ? because if this is made in a shop that's a disaster
