12v power outlet has no power
Old Dec 18, 2023 | 10:23 PM
Kayne70's Avatar
Kayne70
Default 12v power outlet has no power
Last week I had a low tire at work on my 2005 Dodge Ram 2500 so I plugged my potable compressor into the 12v power outlet and while airing up the tire the compressor stopped working. I started the basic trouble shooting ( making sure the plug was in all the way, checked the fuse on the compressor) all was good. I plugged it into the cigarette lighter and it worked. I checked my fuses for the outlet and even though it was good I replaced it anyway and still doesn’t work. Does anyone have any ideas on what the problem could be?
Old Dec 20, 2023 | 10:42 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
If it's old enough they sometimes just go bad and won't work. I've replaced a few over the years.
Old Dec 20, 2023 | 11:59 AM
Kayne70's Avatar
Kayne70
Default Thank you
Thank you for the advice….. That is actually my next step because the wires powering it are good and have power to them so I will order one in.
Old Dec 21, 2023 | 11:39 AM
Alex Medeiros's Avatar
Alex Medeiros
Between the 2 1500s I've had in the family, both had at least one go out randomly. It's just one of those weird quirks with these trucks...
Old Dec 22, 2023 | 05:36 PM
Dodgevity's Avatar
Dodgevity
What happens if you plug the compressor into another car's 12V outlet? That would tell you if the issue is the compressor or your truck's outlets.
Old Dec 22, 2023 | 07:02 PM
Kayne70's Avatar
Kayne70
Default Other cars outlet
The compressor is good. It works when I plug it into my cigarette lighter and turn on the key.
issue has now been resolved with a new outlet
