3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
What manner of steering box do you have? Is it the recirculating ball feller, or rack and pinion? (don't go by what the build sheet says, according to mine, it says I have rack and pinion, and that most certainly is NOT the case.)
What size tires? The stock 20s were 33 inches tall. Sometimes people start adding aftermarket fixes when all that is needed is to replace worn out suspension parts.
already replaced the steering ball joints,upper and lower control arms and even the aluminum steering piece that connects the control arms together ( can't think of the name of that part lol) plus replaced both front gas shocks with the heavy duty coil spring version. so basically I am looking to keep the rubber going straight when one wheel hits that deep pothole
Tires are Yokohama Geolander Size LT295/60R20
