Doors won’t stop locking
Old Jan 26, 2024 | 12:34 AM
Opq36's Avatar
Opq36
Default Doors won’t stop locking
I’ve got a 05 2500 diesel, the doors will not stop locking I’m talking like every 5 seconds. It does it while driving and parked and off pretty sure it was doing it for hours before I noticed the first time. I’ve unplugged both switches simultaneously so it’s not either switch and the plugs in the door panel look okay. Has anyone experienced this? Resorted to pulling the fuse for now but would like to fix this.
Old Jan 26, 2024 | 07:32 AM
Maybe try disconnecting the battery for a bit to reset everything.
Old Jan 26, 2024 | 08:16 AM
Not a stuck button on your fob is it??
Old Jan 26, 2024 | 09:47 AM
Opq36's Avatar
Opq36
No truck had an aftermarket viper system for keyless entry and I removed that thinking it was the problem but it wasn’t so no fob is connectors to the truck at all right now.
Old Jan 26, 2024 | 09:58 AM
aleekat's Avatar
aleekat
Different vehicle. Neutral safety switch went bad. Vehicle didn't know what gear it was in so cycling.
Old Jan 27, 2024 | 12:32 AM
William Scott's Avatar
William Scott
did you talk to your dealer about the issue ?
Old Jan 27, 2024 | 12:56 AM
Opq36's Avatar
Opq36
Figured it out after taking the driver door apart and replacing the lock actuator but that did not fix it. It ended up being the security alarm switch behind the lock cylinder. Turns out that it’s a discontinued part so I just took it out should be fine for now might try and get a used but they were discontinued because they’re defective.
