2003 Dodge Ram 1500 5.9l motor mount solution
I took the old ones out, removed the rubber insert and that aluminum thing. I found this thread and new I had to come up with a solution on my own. I pulled out the grinder and exposed the metal on both sides of the mount, then went to HomeDepot and got a 3/16” x 2” x 4’ steel bar. I cut the steel to fit on both sides of the mount and welded it to the mount. Then drilled a 1/2” hole in the center of the steel on both sides for the bolt. It wasn’t wide enough so I went to Orielys to get spacers, I needed 3 on each side to fit snug, tack weld those in place. Let it cool then paint and install it. Bam solid mounts in the work truck.
