3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Have a 2008 5500 6.7 w AISIN transmission. Have previously gotten codes P0706 / P0708 and limp mode, issue has been intermittent and gone away once truck was shut off... I am now getting a no crank issue, key ahead either P or N selected but no crank. All lights and other functions work. I'm lead to believe its the Neutral safety switch, but dealer is a week at least out on parts and nobody else stocks. This is a plow truck we need to get going in the next couple of days for a storm. Is there a way to bypass the NSS to start the truck in the meantime? I don't care if I have to leave the truck running afterwards until we are finished.
Bad starter??? If you are hitting the correct terminals.... (usually, there are only two, main power feed, and the trigger wire for the solenoid...) and it doesn't do anything, there is definitely something amiss there.
