2002 2500 Sifting Issue
Old May 6, 2024 | 03:20 PM
m2b1's Avatar
m2b1
Default 2002 2500 Sifting Issue
I have an issue when shifting from 2nd to 3rd. No mater how long I hold the accelerator down it won't sift. I have to release the accelerator and then press it again before it it will shift into 3rd and beyond. I have changed the transmission filter, gasket, and fluid when I first got the truck. I have been doing a little research on this and found there is also a solenoid in there but wasn't sure if that would solve my issue. Anyone have any suggestions?
Old May 6, 2024 | 04:40 PM
Which engine/trans do you have?
Old May 6, 2024 | 04:56 PM
m2b1's Avatar
m2b1
diesel, not sure on the transmission.
Old May 6, 2024 | 05:13 PM
Likely 48RE. Its likely just an electronics problem. Changing the governor pressure sensor and solenoid *should* fix it. Get the borg warner heavy duty solenoid.
