OBD for quick-learn?
Old May 16, 2024 | 03:44 AM
Nyqmatti's Avatar
Nyqmatti
Default OBD for quick-learn?
Hi,
is there any affordable (under 300€ or $) tester that have quick learn for -04 Ram 4.7 with 545rfe? Or do i have to just use drive&learn method? If so, how many miles its gonna take to learn and am i right that wot is forbidden?
Old May 16, 2024 | 07:30 AM
What does it have to learn?
Old May 16, 2024 | 08:03 AM
Nyqmatti's Avatar
Nyqmatti
I am going to rebuild my transmission and i have heard that it should be ”reset” with that quick learn method
Old May 16, 2024 | 09:33 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Quick learn is non-negotiable. If you don't do one you will likely negate all that work you're going to do. Quick learn resets and forces the trans portion of the PCM to learn the clutch value index (CVI) for the new trans. Once it learns this for a trans, it bases the shifts on your driivng habits and the clutch values. Allowing to shift operating on the old values can screw up your fresh trans (not that it would take much, the RFE is crap).
Old May 16, 2024 | 11:07 AM
Nyqmatti's Avatar
Nyqmatti
So if i need to do one, and have zero possibilities to do it in my area, is there a tester which have this quick lesrn option and wont break my bank?
Old May 16, 2024 | 04:54 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
So you're asking for a super cheap option for dealer level software LMAO? Whatever it is, it won't be more expensive than another broken transmission. Just take it to a dealer or trans shop, it'll cost you an hour's labor.
Old May 16, 2024 | 05:22 PM
Nyqmatti's Avatar
Nyqmatti
I founded this Foxwell nt501 elite scanner from a Jeep forum. And they said there that it can handle the tranny learning. Maybe i try it because we dont really have much options for shops with Chrysler scanners up here. Nearest i have found is in Espoo, Finland and it’s almost 700km from my home .
