Codes p0800 and code p0080
Old Jul 3, 2024 | 02:41 AM
C.Rod1500's Avatar
C.Rod1500
Default Codes p0800 and code p0080
I have a 2005 Ram1500 v8 2wd and I've been having this issue with it it's something I've never dealt with in any of my ram trucks. So it has power battery is in great condition everything works inside and out the only thing is it won't turn over at all and what's weird on the shifter on the P it doesn't show the square indicating what gear it's on and once that's square pops up that's when the fuel pump kicks in and decides to start can anyone help me on how to solve the problem thanks much appreciated
Old Jul 3, 2024 | 09:14 AM
Next time it does that, put the trans in neutral, see if it will start.
Sounds like the trans range sensor is failing.
