3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
My 2007 2500 hemi, has bent the same pushrod twice in 25 miles. During those 25 miles, it ran perfect. No ticks, no hiccups, nothing.
but #2 cylinder has bent the same rod twice.
I pulled the head, and the lifters look great. I scoped the cam shaft, it looks great.
the rod is found outside its rocker cup, so the intake valve doesn’t open all.
The intake and exhaust push rods are different lengths. After the 2nd push rod failed. And you had the cylinder head off. I would install a new set of lifters. Also check your rocker arm shaft too. These motors are notorious for camshafts going flat.
