08 5.7 engine swap into a o5 with a blown 4.7
They are both 3rd generation ram 1500 quad cab 4x4 trucks and both hemis but the 08 was roled but still runs and drives that I bought from a friend for $1800. I was told that everything was the same and it would be a easy swap. If anyone can help me out and let me know if it will work and what is expect with getting it done I would be a very happy man. Any help will be appreciated
Let me understand, You have a 2005 1500 with a 5.7 that is blown engine and you want to replace it with a 5.7 from an 2008 1500. The engines may look the same, but maybe some other changes you may not see. Like the flex place, injector, timing and some small other details. I would if you are going to replace the motor with an 2008 1500. I would have the side by side before installing into the truck.
You may have a problem switching from a 4.7 to a 5.7. Wiring and computer (PCM) As well has the flex plate. I recommend to find a reman motor 4.7 and all you nee to do install it. But also remember, the 4.7 has two different timing sprockets on the right side camshaft. Some years had a running change.
Thank you for answering my post.i have both full vehicles complete and I am now thinking of possibly getting the o
08 put back together with my 05 as the doner vehicle now if I can figure out the tipm problem and I have been getting some very good information on here for trouble shooting them and unlike my friend I don't feel like it is worthless or more of a problem than it's worth and putting the dashboard and body panels from my 05 and swapping out the CV axle would be fairly easy seeing as they were removed from the 08 when he gave up on it. So now it's going to come to the tipm in the 08 I think at this point.please send any ideas or suggestions.
