TPMS not detecting location
Old Dec 5, 2024 | 09:29 PM
Cameron1173's Avatar
Cameron1173
Default TPMS not detecting location
Hello all I have a 09 2500 6.7 with the tpms light on. It’s throwing a code tire sensor location undetected. I got new sensors when I got new tires last week And found the right side transponder sensor wires were cut. Fixed the wires but still getting the code even had the tire guy use the tool to force it through the obd port.i know that the truck is recognizing the sensors because on my scanner it tells me the sensor id’s and pressures (which are so thing spec). I’ve done some research and found you have to sit for 20 minutes with engine running to get to work. Is that how it clears the code?anyone else have this issue? I’m tired of the light being on.
