Does new camshaft position sensor for ‘05 Ram 1500 5.7 O-ring already installed?
Old Dec 23, 2024 | 12:45 PM
OtisBlue's Avatar
OtisBlue
Default Does new camshaft position sensor for ‘05 Ram 1500 5.7 O-ring already installed?
I changed out the camshaft position sensor and forgot about the manual saying to examine the o-ring on the old sensor. Does this mean that the new
sensor does not come with a new o-ring already installed on the sensor? Thanks in advance.
Old Dec 23, 2024 | 03:15 PM
Los_Control's Avatar
Los_Control
Probably wants you to be sure the old 0-ring has been removed and not left in place.
If the cam sensor needs a 0-ring a new one would come with the sensor.
No manufacturer would rely on a old used o-ring to seal their product and get a bad reputation because of a old o-ring.
Question is now, does your old cam sensor have a o-ring or did it get left in the engine?
Old Dec 23, 2024 | 03:44 PM
OtisBlue's Avatar
OtisBlue
Thank you. I thought I’d check the forum before I dug the old one out of the trash can.
Old Dec 23, 2024 | 05:19 PM
OtisBlue's Avatar
OtisBlue
Old sensor did have the o-ring on. It fell apart pretty easily when I pried on it. Crankshaft sensor and cam sensor both replaced, now to do a computer reset.
Old Aug 21, 2025 | 09:19 PM
Jfmjr1965's Avatar
Jfmjr1965
Default Crankshaft sensor replacement
Did you just replace and start? I replaced mine and it won't start. Any ideas..?
Old Aug 23, 2025 | 07:29 PM
Potato_Couch's Avatar
Potato_Couch
Did it run before you replaced sensor? Did you do the reset procedure? If not, cam and crank may be out of sync.
Old Dec 1, 2025 | 03:21 PM
siclamb's Avatar
siclamb
Some aftermarket sensors have different specs, maybe to long or to short. Not picking up signal. I had that on a ABS sensor before
