2002 Dodge 1500
Old Dec 28, 2024 | 07:21 PM
Brandon18's Avatar
Brandon18
Default 2002 Dodge 1500
02 1500 2wd throwing a p0320 and p0700 code. Left me stranded roadside. Towed home. Changed the crankshaft and camshaft sensors. Motor will turn but won't start. Does anyone know of anything I can check next?
Old Dec 28, 2024 | 07:37 PM
If it cranks, but won't fire, find out what's missing, fuel or spark. I would like to think you aren't driving in a vacuum, so, air shouldn't be the issue.
Old Dec 28, 2024 | 07:50 PM
Brandon18's Avatar
Brandon18
Fair. I changed the oil as well and it had a deathly smell I've never smelt before it looked milky as well (pic attached). I'll dig more into it this week sometime and see what I can find. What's the first thing I should look at? I'm not extremely mechanically inclined btw. So this is all mostly new to me.
Old Dec 28, 2024 | 09:46 PM
That does not look good..... Are you losing any coolant??
Old Dec 28, 2024 | 09:57 PM
Brandon18's Avatar
Brandon18
Doesn't appear any was missing no.
Old Dec 28, 2024 | 10:55 PM
Prismatic's Avatar
Prismatic
While the motor is cranking, does it sound like each cylinder is contributing compression? It'll go like Whir Whir Whir Whir Whir Whir consistently. If a cylinder or multiple cylinders are low on compression you'll hear it go like Whir Whir Where Whir Whir Whir
That oil looks super uh, contaminated. Is that material attracted to a magnet?
