Headlight trouble.
Old Mar 14, 2025 | 01:33 AM
ScarceHades's Avatar
ScarceHades
Default Headlight trouble.
So this is really odd when I got the truck the only headlight that worked was the driver side high beam. I didn't have a lot of time to work on it but I found the passenger headlight would turn on if I ran a wire from the ground to the main ground connection. The head light stays on until I unhook the wire. I'm looking to see if anyone knows where I should start with troubleshooting.
Old Mar 14, 2025 | 09:40 AM
What year is your truck?
Old Mar 14, 2025 | 09:41 AM
ScarceHades
Oh, my apologies. It's a 2007 1500 SLT 4x4
Old Mar 14, 2025 | 09:43 AM
You can find wiring diagrams for your truck here. Have a look at how the headlights are *supposed* to work, and see what part of the circuit is failing.....
Old Mar 14, 2025 | 09:52 AM
ScarceHades
Thank you, I will read up about it. I was also looking to see if people with more experience think this is a wiring issue or the TIPM itself.
Old Mar 14, 2025 | 10:39 AM
Ouch.... Lookin' at it, the headlight switch just suggests to the TIPM what you want to happen..... TIPM decides if it actually DOES happen. Headlamps are individually controlled from there..... So, yeah, I am thinkin' that's is likely a TIPM issue. See if you are getting power TO the headlamps, if not...... Probably TIPM.
Old Mar 14, 2025 | 10:41 AM
ScarceHades
That's what I was thinking, but since the one headlight does work, I was hoping it might just be a ground issue.
Old Mar 14, 2025 | 10:49 AM
TIPM Supplies power to the headlights, ground is a hard connection..... so, apply power, and they work, there are individual drivers for each headlight..... so, it's possible to have all of them working, or none, or anything in between.... I don't know how 'repairable' those circuits would be in the TIPM..... Never had one apart....
Old Mar 14, 2025 | 11:09 AM
boatwire's Avatar
boatwire
Same thing happened to my '04 1500 5.7Hemi. New TIPMs are unavailable. $125 for a refurbed TIPM. Arrived in less than a week...and they give back 10% when you return yours for core deposit...Free USPS return shipping label included.
https://tipmrebuilders.com/shop-tipms-and-repairs/
Old Mar 14, 2025 | 11:13 AM
ScarceHades
All of the TIPMs for 07 on that site are $800 plus.
