Two piece seat conversion
Old Aug 8, 2025 | 08:01 PM
Jettywookie@gmail.com's Avatar
Default Two piece seat conversion
Hello all since this is my first post take it easy on me if this topic has been covered before. My 04 quad cab has the one piece rear seat however I’ve seen some trucks with a two piece rear seat. I want to have my portable fridge installed behinds the driver seat but don’t want to lose the flip up capability of the seat. I’m wondering if anyone may have swapped to a two piece rear seat and deleted the one side and added a fridge slide? Or if anyone has any other ideas?
thanks
Old Aug 8, 2025 | 08:19 PM
Best bet would be try and find a truck that has one in a local junkyard, see how everything mounts, and if it is adaptable to your truck.
Welcome to DF!
Old Aug 11, 2025 | 12:12 AM
Prismatic's Avatar
Prismatic
The 60/40 rear seats are totally independent. You can take out one or the other.
Old Aug 19, 2025 | 09:19 AM
FabricGATOR's Avatar
FabricGATOR
All the chassis attach points should be universal. then seat options are 'plug and play'
My truck has the 60/40
When I first got it, I was at salvage and found a neat under seat system that stows under for normal but unfolds out to make a flat (elevated, level) cargo area.
Wait, maybe my bench is full across but the cargo flip is 60/40... either way, I took a chance and it bolted right in. Best part was I think they only charged me $40
2002 Dodge Ram 1500 Program #2103 - MotorWeek
Dodge Ram Crew Cab Rear Seat Stuck And How To fix it
