2003 Ram with disapearing gear noise
Old Oct 22, 2025 | 09:09 PM
Luckhasnothingtodowithit's Avatar
Default 2003 Ram with disapearing gear noise
I have a 2003 Ram 1500 4x4, Auto, 4.7L V8 about 115,000 mi. For the past few months I have been hearing some "gear noise" when traveling down the road. The type of gear noise you hear when running in a low gear is the only way I can describe it but very muted. I mostly noticed it with the windows rolled up and no radio playing. Lately it has become more pronounced and has gotten louder. I noticed that when I go around a right hand curve, the noise will stop only to return as soon as I straighten out. If I turn left, the noise gets a bit louder. Other than that the truck runs as expected, shifting smoothly. I can put it into and out of 4wd with no problem. There is no vibration. I was kind of thinking it may be a wheel bearing ready to go out. Any other ideas what might be happening?
Old Oct 22, 2025 | 09:41 PM
Left side wheel bearing. When you turn right, you are unloading the right side, and putting more load on the left.
Old Oct 22, 2025 | 09:58 PM
Thanks, I'll check it out
