Hard Steering for my wife when parking
Old Nov 4, 2025 | 06:58 PM
Interested's Avatar
Interested
Default Hard Steering for my wife when parking
My wife can barely turn the steering wheel when parking her 2005 Dodge Ram 1500 4/7 L (165,000 miles)
The pump is not noisy and the belt and tensioner are both good.
Anything above idle is fine.
Is it pump time?
Thanks! Ben
Old Nov 5, 2025 | 08:00 PM
Alex Medeiros's Avatar
Alex Medeiros
If it's the original pump then it should definitely be checked closely. Is it hard to turn all the time, or only in certain intances?
Old Nov 5, 2025 | 08:51 PM
dodgetruck2's Avatar
dodgetruck2
Periods of low engine RPM or slow/zero speed making the wheel hard to turn does seem to be signs of a pump getting weak, is the fluid level good?
Old Nov 5, 2025 | 09:36 PM
Interested's Avatar
Interested
Default P/S pump
Yes. Full and cherry red.
Old Nov 5, 2025 | 09:37 PM
Interested's Avatar
Interested
Only when parking.
Old Nov 9, 2025 | 12:39 AM
ol' grouch's Avatar
ol' grouch
Originally Posted by Interested
Only when parking.
She hasn't been rude to the truck has she? Newer vehicles tend to be more sensitive to comments made when driving. Nothing like a pouty truck to make one driver life miserable.
On a more serious note, I've seen pumps with improper fluid used in the past have problems with the pressure valve. Does this truck have a steering gear or rack and pinion? If it's 4wd, is the steering damper in good shape or getting stiff from dirt intrusion? this is assuming the idle speed is normal.
Last edited by ol' grouch; Nov 9, 2025 at 12:41 AM. Reason: i kant spel wurth a durn
