brake line measurements
Old Nov 9, 2025 | 11:48 AM
truk's Avatar
truk
Default brake line measurements
someone surley has the lengths for buying a complete set of the generic b r a k e line sections?
im guessing 6 lines and 4 hoses?
mine is a 2002 dodge 1500 slt 4.7
needs more data
12mm fittings
11mm?
bubble flare
inverted?
https://www.moparpartsgiant.com/part...agram=00i59462
Old Nov 9, 2025 | 11:51 AM
truk's Avatar
truk
do i need to repelace the calipers
im at 220k they seem to work good now.
Old Nov 9, 2025 | 03:21 PM
If it ain't broke, don't fix it.
Old Nov 11, 2025 | 10:25 AM
Alex Medeiros's Avatar
Alex Medeiros
This. Don't mess with them if they work fine!
Old Nov 12, 2025 | 09:22 AM
truk's Avatar
truk
well the lines are rusty so.
Old Nov 12, 2025 | 09:46 AM
You can get pre-bent lines, but, they ain't cheap..... Or, you can get bulk line, and cut/bend it to fit your needs, (need a flaring tool as well....) Or, you can get lines that are 'close' to the right length, and bend them to fit. Just depends on how much work ya wanna do.
Old Nov 17, 2025 | 04:05 AM
DJG11704's Avatar
DJG11704
Default Brake lines
First, unless you know the condition of your calipers, replaced recently. Just replace them. FYI, what makes the calipers stick is rust and dirt, second. What brings the piston back ( retract ) is a square O ring seal, that deforms into a parallelogram, when the brakes are applied, then it pulls the piston back ever so slightly to give the pads room for clearance. So when they get old , the seal won’t pull the piston back, thereby causing the breaks to drag. Destroying the pads, rotors and calipers 👍
For the brake lines. Go to Harbor Freight and buy a set of flareing tools and benders. You will learn a new skill, save money and have self satisfaction of doing it yourself 👍
