Low voltage circuit A
Old Jan 28, 2026 | 08:45 AM
Rigo cardoza's Avatar
Rigo cardoza
Default Low voltage circuit A
I have a 2006 dodge 2500 4x4 5.9 cummins and I get a check engine light only in cold weather low voltage circuit a can't figure out truck doesn't perform any different runs fine can anyone help me figure it out
Old Jan 28, 2026 | 08:52 AM
dodgetruck2's Avatar
dodgetruck2
what's your code number, is it injector circuit?
Old Jan 28, 2026 | 08:57 AM
Rigo cardoza
P0642
Old Jan 28, 2026 | 09:03 AM
Rigo cardoza
That's the only thing that comes up only in cold weather summer doesn't come on
Old Jan 28, 2026 | 09:57 AM
dodgetruck2
alright, its a sensor supply code, ill have to pull a schematic and see what sensors run off that supply, I'm guessing its a temp sensor and its bad enough that the cold weather shorts it out, once it warms up it quits shorting
Old Jan 28, 2026 | 10:01 AM
dodgetruck2
base on code description it looks like only the fan runs this circuit, inspect the fan harness where it goes up between the radiator and the fan and see if its rubbing anything
Old Jan 28, 2026 | 10:03 AM
Rigo cardoza
I'll do that
Old Jan 28, 2026 | 10:59 AM
Rigo cardoza
I've checked the wires nothing seems to be rubbing for thr first time another code came up p0069 I need to mention I bought this truck five years ago it has a live tunner in it with a air dog filter and has done this every year would that have anything to do with these codes
Old Jan 28, 2026 | 09:34 PM
dodgetruck2
imp surprised it doesn't run different, the baro/map sensors are crucial for fueling, mines setting a map code right now has zero power and no boost at all
Old Jan 28, 2026 | 10:20 PM
Rigo cardoza
It has a boost fooler would that cause a problem i unplugged it sometime back didn't make any difference
