air ride
Old Jan 23, 2006 | 10:01 PM
2002ramon24s's Avatar
2002ramon24s
Default air ride
ok guys time for a little help. i sold the wheels off my old car i traded in on the ram. well now i have the money to air bag my truck. first problem is i have 24s. i know i need to remount my upper conrol arm. and shorten my rear end. well thats all fine. what im asking right now is anyone here with air bags i wouldnt mind talkin to ya a little bit about probs u had and things like that. i got msn yahoo and aol. now if u would shoot me over a message and lets talk. i got about 1900 to spend and i am planning on doing 95% of the work myself. i have bagged 4 other things already. well my msn name is bmph8er my yahoo name is bmph8er and my aol is dubbedcord. so send me a message thanks.
Old Jan 23, 2006 | 10:31 PM
spiffdank3.7's Avatar
spiffdank3.7
Default RE: air ride
PLEASE take pictures of the procedure, cant wait to se it
Old Jan 23, 2006 | 11:20 PM
2002ramon24s
should be getting done in 3 months hoping to start a week beforen april and be done may 1st. while working on it only after work and on weekends. also soon bell tech drop kit for sale haha
Old Jan 24, 2006 | 10:35 PM
2002ramon24s
i know i have seen rams with air ride. now come on ppl help someone out for once
Old Jan 25, 2006 | 02:04 AM
platinumcarclub's Avatar
platinumcarclub
What type of questions do you have? I have an 04 Ram wtih front, back, side to side, pancake, and see saw. I dont have 24 but do have 22. Were are you located?
Old Jan 26, 2006 | 04:24 PM
2002ramon24s
located not to far from u. im from effingham illinois. i was wanting to see about the front suspention. im mostly needing info on the upper control arm on where u cut how much to lift it and what u used and just little things like that.
Old Jan 26, 2006 | 08:24 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
Your on the wrong site...Most of the guys here don't know what 'bags' are. Let play fill in the blanks: www.Dodg_Tal_.com There is a whole section dedicated to dropped, bagged and lowered trucks. They will give you answers. PM me if you need the site.
Old Jan 26, 2006 | 11:44 PM
platinumcarclub
In the front the only thing that was cut was the upper spring basket on the frame. This was to give the bag room to expand when it was dropped. We removed the coilover package and installed the bag in its place. You will need to lift the bag out of the lower A frame because it will rub on the side walls and will pop it. I forgot how much we raised it but I think it was more than 5". We had relocate the shock to the rear of the A frames and I am riding 22s and they rub slightly. I dont know what to do with 24s. The only thing that comes to mind is that you are just going to loose alot of your turn radius. Let me know how it goes and if you have any more questions.
Old Jan 28, 2006 | 11:51 AM
2002ramon24s
ok think i got 99% of my answers. i have to cut the upper arm off and raise it 3 inchs and cut off the upper coil spring pocket and make my own bag mount there. and flip the lower ball joint then that if it still isnt low enuff Z the frame in the front. then after that little bit of stuff the front is done. the rear i have to shorten my rear end 4 inchs each side and then do the normal bag stuff. the 4 link really really big notch fuel cell and litthe things like that. so looks like i got a lot of stuff ahead of me.
