Factory Uconnect Locations
Old Feb 1, 2006 | 09:49 PM
drquick's Avatar
drquick
Default Factory Uconnect Locations
just bought an 06 slt quad cab i have already done a factory install of the NAV radio and i have pucrhces the 3 items to install the factory uconnect the mirror the module and the harness. the problem im having is where is the factory module suppossed to go and where is the harness supposesd to be plugged in to
Old Feb 2, 2006 | 03:31 AM
chiledude's Avatar
chiledude
Default RE: Factory Uconnect Locations
The Telematics module mounts to the right side of the dash. If you look under the dash between the glovebox and the end of the dash you will see were.
There is an end cover you need to remove, then you will see were it mounts.
Also what part number is the mirror harness cable you are using?
As far as plugging into your dash harness the plugs are probably not there.
See the other posts on uconnect, there is some links to tell you what's going on.
I'm in the same boat!!!
