Rear End Gears
Old Feb 2, 2006 | 03:26 AM
justint420's Avatar
justint420
Default Rear End Gears
I have not figured this answer out yet so here goes the question. I have a 2003 Ram 1500 4x4 with 3.92 gearing. Is this a "posi-traction" axle, or whatever other terms its reffered as? My g'pa has a Z71 and always says he has a "positive-traction" rear end. Is my axle in the same boat as his? BTW I do not believe his is 3.92. Its either 3.55 or 3.73, its a 2002 Z71.
Thanks for helping me figure out what kind of axle I have.
Old Feb 2, 2006 | 09:11 AM
AIR RAM's Avatar
AIR RAM
Default RE: Rear End Gears
If you have the "limited SLIP" diff it would be the save as POSI traction... they all call it a different name although its the same thing. All you need to do is look in your glove box... you will find a white sticker which gives the details of your type of axle... or just climbe under the truck ... you should have stickers on either end of th eaxle which tells you whats in them... .
SPEED SAFE, AIR RAM
Old Feb 2, 2006 | 10:41 PM
justint420's Avatar
justint420
The glove box sticker just says axle: 3.92. Does that mean its not a LSD?
Someone had me put it in 4wd and turn the steering as much as I could and see if one back tire would spin as fast as the other, based on what this person saw they said it was LSD. What do you think?
Old Feb 4, 2006 | 03:40 AM
justint420's Avatar
justint420
bump
Old Feb 4, 2006 | 05:10 AM
muddauber5.7's Avatar
muddauber5.7
you want a quick way to tell, just brake torque your truck until your rear wheels break loose. Then back up and see if you have one or two black lines. Ha Ha it's that simple!!!
Old Feb 4, 2006 | 07:58 PM
chickenbag's Avatar
chickenbag
I just had my 02 dodge checked out at a dealer and they ran my vin to see the options that my truck had and as an option it has an anti spin dirrerential rear axel meaning true posi, so its ofcourse my opinion if its limited anything its not posi
Old Feb 4, 2006 | 08:22 PM
AIR RAM's Avatar
AIR RAM
Limited slip is the SAME as POSI... so if the sticker in your glove box says limited slip or LSD then you do infact have the DODGE version on the chevy POSI unit.
SPEED SAFE, AIR RAM
Old Feb 5, 2006 | 02:36 PM
AIR RAM's Avatar
AIR RAM
If you do NOT have LSD on your sticker than that means its a "ONE WHEEL WONDER"...
SPEED SAFE, AIR RAM
