Loss of Power...
Old Feb 3, 2006 | 06:41 AM
HardC0r3H3mI's Avatar
HardC0r3H3mI
Default Loss of Power...
For some reason it seems ive lost a lot of power in my Hemi. I have about 38000 miles and after i hit 36000 it seems like it doesnt get up like it did before.....anyone else see this? any suggestions??
Old Feb 3, 2006 | 06:44 PM
sandiegohemi's Avatar
sandiegohemi
Default RE: Loss of Power...
Did you replace the spark plugs at 30,000 miles? If not, that may be the problem. Dodge recommends replacement every 30K.
Old Feb 4, 2006 | 07:37 AM
silvernightmare's Avatar
silvernightmare
Yeah, replace spark plugs and maybe spark wires and then get a tune up. After all that everything should be back to normal.
Old Feb 9, 2006 | 11:50 PM
HardC0r3H3mI
Thanks, ill try that...
Old Feb 13, 2006 | 07:49 PM
hemi24s's Avatar
hemi24s
did it happen around the time you put on yourrims? i noticed a significant power loss when i put on my 24s, which is what i expected beause of al the additional weight. you should also consider getting some new gears like a 4:56 setup. i put it on mine and it runs like hell now. its also recommended you do that when you go to a tire size changeespecially if you had the 17's on there b4
Old Feb 14, 2006 | 04:47 PM
motorhead426's Avatar
motorhead426
Hemi's have platinum plugs. They are supposed to be changed every 100,000 miles, not 30,000 miles. Larger rims would definitely cause you to feel a power loss. You could also have a few other things going on. For instance, I'd assume you know to check the air filter, and fuel filter. A faulty EGR system can also cause significant power loss. Are you still getting the same fuel economy as you used to? A faulty ERG should send the engine light on. just my $.02
Old Feb 14, 2006 | 04:56 PM
silverburst's Avatar
silverburst
My 04 hemi manual says to change the plugs at 30,000 miles as well....
ORIGINAL: motorhead426
Old Feb 14, 2006 | 05:49 PM
motorhead426
hmmm....
