26 gallon tank to 34 gallon?
Old Feb 8, 2006 | 03:19 PM
motorhead426's Avatar
motorhead426
Default 26 gallon tank to 34 gallon?
So obviously they fit, with the 1500's having the same frame truck to truck, but what else would you need to install them? Would the PCM recognize the change? Are the sending units different? Or are the tanks just longer, and not deeper? I have been thinking about this becuase I originally wanted the larger tank, but couldn't find a truck last June with it and all the other options I wanted.... Any input on this? I'm taking my truck into the dealer Friday for some head liner issues (around the sunroof trim), and I might search around on their parts computer for this fuel tank idea.
Old Feb 8, 2006 | 03:41 PM
osteodoc08's Avatar
osteodoc08
Default RE: 26 gallon tank to 34 gallon?
I believe someone around here has already done this, but required getting a new sending unit and flashing the computer for an accurate read with the 34 gallon tank. I have the 34 gallon tank and at a blistering 12.5-13.5 in my almost 100% city driving, I couldn't imagine having the 26 gallon tank. Yeah, sure 8 gallons, whoopeeee, but seriously it does allow me to go another week without filling up, which I reallylike. It just hurts more to fill it up
Do a search as this topic popped up a while ago and has a little more info like part numbers and such.
Old Feb 8, 2006 | 03:43 PM
HankL's Avatar
HankL
The 1500 frame and the 2500 frames are not exactly the same,
with the 2500 frame slightly deeper.
What you are looking for is the 34 gallon gasoline tank
similar to those installed in V10 2500 Quad Cab or Club Cab
shortbed trucks.
The 36 gallon gasoline tank like that installed in long bed 2500 series Rams will not fit.
I have read at least one post from a 2nd gen Ram owner who claimed that he
ordered the 34 gallon gasoline tank new for about $290 from his local dealer
and had the dealer install it in place of his 26 gallon tank.
see info below:
Here's the info embossed on the 34 gal. tank on my
2001 2500 QC SB (V-10):
Nautex Avilla 13827
52102241AD
52102238AG
"PE-HD" (underlined)
Old Feb 8, 2006 | 03:47 PM
osteodoc08's Avatar
osteodoc08
ORIGINAL: HankL
shortbed trucks.
see info below:
Nautex Avilla 13827
52102241AD
52102238AG
I think he is referring to the $50 option on the 3rd gen QC trucks to have a 34 gallon tank as opposed to the std 26 gallon tank. I do understand what you are saying about the 36 gallon tanks, but I think he is inquiring about the optional 34 gallon tanks on the 1500 QC Ram's.
Old Feb 8, 2006 | 05:14 PM
toxdoc's Avatar
toxdoc
I have a Laramie with all the bells and whistles, options, etc. and I would appreciate hearing what the dealer does for you regarding your headliner issues. My headliner edge shows on the front side near the sunroof trim ring. It may not be bad or even noticeable but it should NOT be something we have to fix ourselves.
Thanks for your reply and information***
toxdoc
Old Feb 8, 2006 | 06:36 PM
motorhead426
toxdoc you have a email on the headliner.
