moisture?
Old Feb 14, 2006 | 05:28 AM
3/4 HEMI's Avatar
3/4 HEMI
Default moisture?
I found some moisture today when I did an oil change right where you add the oil. Is this common, I looked at the rubber seal and everything looked okay.
Old Feb 14, 2006 | 05:44 PM
Hemimadman06's Avatar
Hemimadman06
Default RE: moisture?
Yea Mositure in the fill cap is always pretty normal on vehicles i have a buddy with and 05 whose got the moisture under the cap and i work for hummer bentley and rolls royce and they all do the same thing.ive seen it on every car.
Old Feb 16, 2006 | 11:29 AM
travie81's Avatar
travie81
If you drive short trips all the time, then yes it's normal. I had the same thing and the dealership said it takes roughly 18 miles to warm up enough to burn all the condensation out.
