axle ratio
RE: axle ratio
ORIGINAL: HuskyJazz
I'm fixing to buy an 06 qc 4x2. I was wondering what was the difference in the axle ratio's. Is the 3.92 ratio better, if so how? And do the 20 rims give a better ride or make any difference at all beside paying more for tires later?
As for axle ratio. Dodge adjusted the axle ratio to fit 1) the tire size originally supplied on the truck 2) to address the desired towing capacity. The numerically higher the axle ratio typically the more you can tow, it's also easier to go up to larger tires w/o having such an impact on performance.
If you plan to eventually order custom rims I would go with the 20" from dodge, unless you think you can sell them w/o loosing money. When deciding which axle ratio you want ask yourself how much you intend to tow and what tire size you plan to run. If you plan to run 33" or 35" tires you'll want to go with 3.92 gears, if you plan to run 31" or 32" and don't plan to tow very much you'll probably be fine with 3.55 gears...
Here in MN the winters do a real number on custom rims, unless a person spends a lot of time taking care of them. I also tow a car trailer and Jeep Cherokee for 4-wheeling ~ 6,500 - 7,000 lbs. Based on this I decided I wanted the factory 20" rims and 3.92 gears. I believe if you order 20" rims you'll get 3.92 gears, if you order 17" you get 3.55 by default unless you specify you want 3.92 gears. I also think that the TX series comes with 3.92 gears.
Let me know if you have more questions.
RE: axle ratio
Hey thanks for the info. The heaviest thing I will tow on any regular basis will be a bass boat. Even then it is not on a regular basis. I probably won't ever buy custom wheels, but I do use my truck to go hunting in so when I have to buy new tires I will prob go with an AT. It doesn't snow often enough to pay for the 4x4 plus where I go hunting I don't really need it. Again thanks for the info.
RE: axle ratio
get the 3.92's! there is NO good reason for the 3.55's at all... They will NOT get you better fuel economey and at best they will make your truck feel like a SLUG... the 3.92's will better serve your 6,000lb+ truck and get you better fuel economey than those 3.55's!
SPEED SAFE, AIR RAM
SPEED SAFE, AIR RAM
