rearend leaking??
Old Feb 28, 2006 | 02:05 AM
sonny t's Avatar
sonny t
Default rearend leaking??
Has anyone else had a problem with thier rearend leakin?? My truck has 26000 miles on it and I found out today its leaking. Its a 2003 RAM1500 quad with the HEMI. This should be coverd under warranty. Anyone else had the problem?? What was the cause???[8D]
Old Feb 28, 2006 | 10:49 AM
osteodoc08's Avatar
osteodoc08
Default RE: rearend leaking??
Is it leaking, like drip-drip. Or is the diff cover a little moist from the oil coming out of the plug? Either way, it is an easy fix. Be forewarned that after the 3/36 there is a $100 "co-pay" for any work done under the 7/70. Might be just easier and cheaper to fix it yourself.
Old Feb 28, 2006 | 08:03 PM
Joe Dirt's Avatar
Joe Dirt
My rearend leaked when I almost wrecked my truck. Nothing a bit of TP and change of shorts won't fix.[sm=smiley20.gif]
Old Feb 28, 2006 | 10:14 PM
Hemi_Chris's Avatar
Hemi_Chris
You should really get this checked out. A bit of moisture may be nothing, but then again it may be signs that the entire rear dif is about to melt down. The rear ends on our Dodge's have this nasty habit of having a retainer clip fall into the gears and basically breaking everything. This can be quite dangerous but is completely covered under warranty. Take it to your dealership ASAP.
Old Mar 1, 2006 | 01:15 AM
kachina_labala's Avatar
kachina_labala
Yep Mine was like that when I bought it. Made the dealer fix it before I would sign the papers. About 23000 miles.
Old Mar 2, 2006 | 01:18 AM
smreish's Avatar
smreish
Yes, and Yes.
39780 miles and the front drive shaft seal (yoke / pinion seal) needed replaced.
And yes, for that 22 dollar seal it cost me the co-pay of 100 dollars.
If you have the patience, dropping the drive shaft and doing it yourself would save some money.
All dry and happy now....1 week later.
