SUPERCHIPS & Long tubes = Blown motor
Old Mar 17, 2006 | 06:44 PM
AIR RAM's Avatar
AIR RAM
Default RE: SUPERCHIPS & Long tubes = Blown motor
The thing is the long tubes would NOT make you lean while NORMAL driving... At first the headers start to lean you out (First few seconds) then the O2 sensors and the PCM will adjust to insure your running 14.75:1 ... But at WOT is when your HEADERS can cause you to go lean because the PCM does NOT use the O2 sensor for correction at WOT.
SPEED SAFE, AIR RAM
