tow haul? 06 mega cab
Old Mar 20, 2006 | 12:41 PM
i11m10c2's Avatar
i11m10c2
Default tow haul? 06 mega cab
do i need to use the tow haul all the time even on flat freeway? the trailer is 1400 lbs and car 3500lbs almost 5000lbs which aint much for the hemi. i ask because it raises rpms and i am doing a 2400 mile trip to washington and i am trying to wach gas milage. i understand hils and passes in the rockys i will need to use but what about the flat?
Old Mar 20, 2006 | 07:34 PM
Joe Dirt's Avatar
Joe Dirt
Default RE: tow haul? 06 mega cab
I would personally say that if it is going into overdrive, and lock-up there should be no need to use tow/haul. If the convertor fighting to stay locked up, then I would recommend using it.
Old Mar 22, 2006 | 12:06 AM
06REDRAM's Avatar
06REDRAM
AT CRUISING SPEED NO NEED FOR TOW/HAUL
Old Mar 22, 2006 | 01:31 AM
osteodoc08's Avatar
osteodoc08
I don't know about the 06 but on my 04, with the Tow/Haul on, it will settle down to OD rpm's while on the highway, but will leave the TC locked up longer and will not downshift until later.
When I tow my parents' boat, I always use the Tow/Haul mode.
Old Mar 22, 2006 | 02:43 PM
Mystro's Avatar
Mystro
If its not shifting around for gears and the road is flat then I would keep it in OD. If it gets hilly and you feel the truck searching for the right gear alot then use the Tow mode.
