I put Ram air on my 04 Dodge Ram 2500 HEMI (pics)
Old Mar 24, 2006 | 06:09 AM
DodgeRamAir's Avatar
DodgeRamAir
Default I put Ram air on my 04 Dodge Ram 2500 HEMI (pics)
I designed this adapter on autocad and a machine made it out of plastic. Can't say I felt a difference in power but you might feel it on the freeway.
Old Mar 24, 2006 | 09:10 AM
MGDMike's Avatar
MGDMike
Default RE: I put Ram air on my 04 Dodge Ram 2500 HEMI (pics)
Awsome! My brother and I did the same thing to his 98 Mustang a couple of years back. Except we didn't use CAD[&o] But I have the program now and it sure would have made our job easier!
Old Mar 24, 2006 | 12:55 PM
Mystro's Avatar
Mystro
Did you put a fine screen on the front of the box to keep the bugs out?
Old Mar 24, 2006 | 02:49 PM
osteodoc08's Avatar
osteodoc08
Beware of deep puddles. Also, what are you using to filter the air coming into the motor?
Old Mar 24, 2006 | 03:51 PM
AIR RAM's Avatar
AIR RAM
ORIGINAL: osteodoc08
Thats his stock filter box... so I would assume he is useing a flat panel style filter.
SPEED SAFE, AIR RAM
Old Mar 24, 2006 | 04:48 PM
DodgeRamAir
I am using my stock ice box, oem style air filter, I have no screen for small bugs since I felt the air filter was enough. I live in SoCal and the ram air opening is so high off the ground so I don't need to worry about hydrolocking. O, and I spent up to 12 hours designing it. I was learning how to use the program and I was trying to perfect the adapter. It's a 6" by 6" plate with a 4" diameter cylinder attached to it. The machine that made it out of plastic.... I was told that that plastic was $12 a cubic inch. Of coarse the college paid for it. The plastic is not so strong so I increased the wall thickness of the plate and cylinder.
Old Mar 24, 2006 | 04:58 PM
rob[GL]'s Avatar
rob[GL]
I think that mod is rediculous, and will only HURT performance, not only that but it looks cheap and ugly too.
The actual fog light air opening looks sweet, you definately desgined and manufactured that well...
But using dryer vent aluminum tubing? Bad idea, look at how rough the inside is, you're just going to create TONS of turbulence... The engineers at DCX did a pretty good job of designing an intake already... Sure you can always make it better, by switching to a cone-shaped air filter, and eliminating the accordian-style rubber hose that connects the throttle body and the air box...
But ADDING extra length to the overall system? I don't think the air down there will be much cooler, than the stock intake location behind the front grille... And as I've already said, with all those rough edges inside the new tubing... You're just going to slow down the air flow that much more...
Turbulence = bad.
Old Mar 24, 2006 | 06:23 PM
silvernightmare's Avatar
silvernightmare
I think i might have to agree with rob, all the grooves in that tubing might cause the air to slow down.
Old Mar 24, 2006 | 07:14 PM
rob[GL]'s Avatar
rob[GL]
I swear, I don't *TRY* to sound like an ******* in my posts... And I'm certainly no engineer... But I'm just trying to help!!
Old Mar 24, 2006 | 09:45 PM
osteodoc08's Avatar
osteodoc08
ORIGINAL: AIR RAM
SPEED SAFE, AIR RAM
Brain Fart! For some reason I thought he was bypassing the filter too, as it wasn't in the picture. Now I realize he was just doing that for illustration only. It's been a long week and the weekend will be even looooonger.[:@]
