Stock Air Filter
Old Mar 28, 2006 | 10:31 PM
MY D8ONA's Avatar
MY D8ONA
Default Stock Air Filter
She has 9,000 on her and its time for an air filter change. Any thoughts on Brand or Type of replacement. She's all stock so I'm looking for a drop in replacement. Fram?
Old Mar 28, 2006 | 10:59 PM
osteodoc08's Avatar
osteodoc08
Default RE: Stock Air Filter
Purolator or Wix. I just swapped mine out for a Purolator at 12K miles. You can also go for the K&N or similar drop ins.
Old Mar 29, 2006 | 11:33 AM
hockeynut52's Avatar
hockeynut52
K&N is my personal Fave. I use it on my motorcyle and truck. And it lasts a long long time. you just have to keep it cleaned and oiled every now and again.
Old Mar 29, 2006 | 12:47 PM
Mystro's Avatar
Mystro
I am going to go with a Fram and replace it on a regular basis. I think cost and the finer filtering of the Fram filter is a better idea for a off-road truck. I do have K&N on my sportscar and other on road vehicals.
Old Mar 30, 2006 | 02:38 AM
oppie311's Avatar
oppie311
My best friend is the head mechanic at a GM stealership and he said that it really isn't necessary to re-oil the k&n (and similiar) filters. He said that he has to replace a ton of air sensors because people with the aftermarket filters tend to over-oil them. The over-oiling can sometimes fry the sensors on late-model trucks. I just use small amounts of oil when I "rehydrate" my filter, and I haven't had a problem yet.
Old Mar 30, 2006 | 11:05 AM
hockeynut52
Luckily, I don't think the 3rd Gen Rams have a mass air Flow sensor, so it should not be a problem cleaning and re oiling the K&N just don't want to do it and gunk up the throttle body. I think Ford and GM still use the MAF so they run a bigger risk with over oiling.
Old Mar 30, 2006 | 02:46 PM
rambob's Avatar
rambob
I know the stock filter that came in my 04 4.7 ram is the same part # that comes in the hemi and 8.0L v10. I think the factory filter is a wix and that is what I went with. A paper filter filters better and factory filters are engineered to flow more than enough air to make the rated horse power.
Old Mar 30, 2006 | 06:39 PM
oppie311's Avatar
oppie311
I was completely unaware. Thanks, now I don't have to worry about it.
Old Apr 3, 2006 | 12:52 PM
mill500's Avatar
mill500
I've used K&N on all my vehicles. There's been some discussion before that a few guys think they pass more dirt than a stock, but I've never seen any type of testing to back that up (it would be interesting to see something on that).
I've usually gotten about 1-1.5 mpg more when I've switched, so it does seem to flow better. I figure even if everything's the same $45 for a filter that lasts as long as the vehicle vs. $14 every 10-12k the K&N is cheaper in the long run.
