3.7 Re-Gear
Old Apr 1, 2006 | 10:23 PM
TEX1500's Avatar
TEX1500
Default 3.7 Re-Gear
Hey Y'all, I am looking at doing a regear from 3.55 to 4.10. If any of y'all have done it already can you please tell me the results. I have a standard and am looking for some more "kick" in 5th as well as through the rest of the gears. (it's an 02 so it's only a 5 speed). I've also heard that this will improve MPG, I'm already getting 18 highway (because of the tires) But every little bit helps! Any tips or advice would be greatly appreciated, thanks
Old Apr 3, 2006 | 04:13 PM
2002ramon24s's Avatar
2002ramon24s
Default RE: 3.7 Re-Gear
added 4.10s when my rear end blew up best thing i have ever done. dont think about it just do it and throw your paper weight away (throttle body spacer) and hows the 40 series sounding to ya
Old Apr 3, 2006 | 11:28 PM
TEX1500's Avatar
TEX1500
Thanks Ramon. I'm looking forward to getting it done. I am going to get rid of the throttle body spacer, I'm also going to replace the throttle body with a fastman 65mm. I love the 40 series. It sounds better than most V8's I've come across, it sets of car alarms everywhere I go, and I've been told I can be heard long before I arrive. I'm not sure what ricey sound people talk about, I've never had a problem with the sound.
Old Aug 26, 2006 | 06:40 AM
marv02's Avatar
marv02
I just purchased a 06 with a V-6, 6 Speed Trans and it has 3.22 rear end gears I was thinking of 3.73 with stock size tires ? won't 4.10 a bit to steep and If I went with 4.10 what kind of RPM's Are you turning at 70 MPH thats most of the HWY speeds around here are I would like some more bottem end but I do mostly HWY driving.
As of now I turning 2100 RPM at 70 MPH in 6th gear I dont want to be turning to many RPM'S and lose my MPG.
And if I do regear will this make any engine or anit lock Brake lights come on will I need to worry about the tone ring.
ORIGINAL: 2002ramon24s
Old Sep 6, 2006 | 03:34 AM
j12racer's Avatar
j12racer
did the 4.10's add just top spped of accel or both thanks
