How do I get to my 04 Dodge ram 1500 speakers ?
Old Apr 2, 2006 | 03:27 AM
dg4icp's Avatar
dg4icp
Default How do I get to my 04 Dodge ram 1500 speakers ?
I would like to replace my factory speakers and I kinda guess the rear speakers require the back storage to be taken out followed by the side panels but the front door speakers I have no idea how to get to. Hs anyone paced thiers ?
Old Apr 2, 2006 | 03:46 AM
BlueHemi's Avatar
BlueHemi
Default RE: How do I get to my 04 Dodge ram 1500 speakers ?
Very simple. First, remove the inside door handle using a 10mm socket or torx head screwdriver. Then remove the philips head screws (1 behind the door handle, 1 at the top front of the door panel, and 2 at the very bottom of the panel) and lift up and out on the door panel. Don't pull too far until you unclip the wires for the power windows/locks. Now you can get to your speaker. Make sure you use the retaining ring that is clipped to the factory speaker when installing your new speaker.
Old Apr 2, 2006 | 01:26 PM
dg4icp's Avatar
dg4icp
Was I right about the rear 5 1/4 speakers ?
Old Apr 2, 2006 | 01:47 PM
parkersdropped03's Avatar
parkersdropped03
The front speakers are 6x9 in the QC doors.
Old Apr 3, 2006 | 03:32 AM
BlueHemi's Avatar
BlueHemi
ORIGINAL: dg4icp
You have a regular cab....correct? If so, then yes you were right.
