New alternator
Old Apr 5, 2006 | 08:31 PM
Hemi_Dub's Avatar
Hemi_Dub
Default New alternator
Looking for a new high output alternator. any ideas. have 2 12s and 7 tvs tham thing goes out after 20 min. already have an optima battery but i was told that only helps a little bit that i need a new alternator for it to last longer, so im waiting to get a new alternator befor putting in the new battery. thx 4 your help.
Old Apr 5, 2006 | 09:08 PM
Gone Fishin's Avatar
Gone Fishin
Default RE: New alternator
http://www.h-o-alternators.com/index.htm Here is a link to someone that will apparently build one for you. I have no idea how much, and I haven't done any business with them, but hey, its worth a shot. They say 200 amps. You also might try looking up a dc auto electric shop (someone who rebuilds these) They may be able to build one for you. Either way, it sounds REALLY expensive.
Old Apr 5, 2006 | 10:50 PM
osteodoc08's Avatar
osteodoc08
There used to be one that was Green something or another. They produced 200+ amp alternators. Stock alternator puts out 136 amps I think.
Old Apr 7, 2006 | 12:30 AM
Hemi_Dub's Avatar
Hemi_Dub
just got an email from HO and you were right Gone Fishin very expensive
Application : 04-03 Dodge Ram 5.7L
HO Part Number : 14921
HO Rating : 220 amps
Our suggested solution to your power needs:
1. Replacement Alternator HO 220 Amp Alternator Model # 14921
Price includes our 1 year hassle free warranty.
Suggested Retail $735 Your Price $649
http://www.h-o-alternators.com/PDF/Web PDFs - Bosch.pdf
Our alternator will directly replace the stock alternator, and interface directly to your car’s computer. No need for brackets or messing with the wire harness. The only change you will make is the output from the alternator to the battery. We recommend 4 gauge or larger.
2. PowrCap We also recommend you add a battery-capacitor to your battery system The PowrCap 400.
Suggested Retail $199 Your Price $149
3. Freight DHL Ground alternator $19
DHL Ground PowrCap $15
DHL Overnight alternator approx. $45
HO alternators are custom built to work with your vehicle’s computer and existing brackets. Please anticipate a one week delivery time due to our current backlog of orders.
Contact me if you have any questions.
Jason Musal
H.O. Alternators
1-866-HI-OUTPUT
Old Apr 7, 2006 | 08:17 PM
Gone Fishin
Well,
I can't say I'm surprised at the price. I know it sounds really expensive, but that's the way of everything these days. I also suggested checking out a local auto electric shop too. You might be surprised by what a little searching around can get right were you live.
Good Luck!!!
Old Apr 8, 2006 | 12:40 AM
LouderthanU's Avatar
LouderthanU
i paid 375 for my 250 amp alt only problem is it is a ford case(they are bigger i believe and have a better voltage reg.) neways just installed 3 weeks ago for Spring Break Nationals and did 151.9 with 4 15' L7's in a wall in my QC i cant get you a number to this place in orlando , only problem is you have to make brackets i put my revs to 800 cause i need the power you most likely wont have to have it reprogrammed i'll puts some pics on my prof. soon good luck on the truck.
Old Jun 23, 2007 | 10:10 AM
itsmejto's Avatar
itsmejto
http://s78.photobucket.com/albums/j1...l-alternators/
Best deal I found is Iraggi Alternators, Dom Iraggi build high output units for a lot of vehicles including a 260 amp direct drop in Bosch unit for the hemi rams, same as the original 136 amp unit. He also made me a set of brackets so I can run dual alternators, the original and a 260. He sells on Ebay, just search for iraggi. He likes to talk to you on the phone but is a tad slow at replying to e-mails.
Here's a ling to his 220 amp for a hemi dodge, he does a 260 also but is not listed here yet.
Not cheap, but these are new Bosch units modified by Dominick
Here you go..
180 $379
200 $399
220 $419
240 $439
260 $459
We also have a dual kit for $219
Thanks, Dom
[IMG]local://upfiles/35436/3A4CDB4EE0D04E0B88F3FA2F765BE1DF.jpg[/IMG]
Old Jun 23, 2007 | 12:09 PM
Pappy_FB's Avatar
Pappy_FB
ORIGINAL: Hemi_Dub
Something else you might want to consider isatwo battery setupwith an isolator.
I mean still get a HO alternator just add a second battery dedicated to yer electronics.
My 2 cents
Old Jun 23, 2007 | 12:44 PM
HuntinHanson's Avatar
HuntinHanson
christ sakes, 7 tvs in a quad cab?!?!?!??!! can you view a tv from every possible angle you'd look in the truck?
Old Jun 23, 2007 | 01:06 PM
trav_19's Avatar
trav_19
why not just get a capacitor like they use for systems
