Want to add Projectors
Old Apr 18, 2006 | 07:19 PM
poolshark2014's Avatar
poolshark2014
Default Want to add Projectors
I have an 04 Ram pickup and wanted to add projectors along with my 10K or 12K HID kit but don't know what bulbs I would need since they change from 9007.Both HID kits I have right now are the Hi/Low kits.What brand of projector is best and where can I get a pair? Also what HID bulbs will I need? Thanks in advance.
Also how much color do projector give off with HID's? I am looking for a deep blue color or deep violet color.
Old Apr 19, 2006 | 01:36 AM
will175's Avatar
will175
Default RE: Want to add Projectors
there was some one that posted on here that put projectors in there stock headlights, it looked really clean. Im about to do the same. Just dont know what projectors to use. If you want to use a good brand HELLA,PHILLIPS are very good ballast. The bulb makes the difference in the color, the higher the rating is on the color of the bulb, the brightnes rating is lower. If you buy projector headlight make sure they are HIDs projectors, it does make a difference. If you dont buy projectors and you throw them in your stock headlights make sure you put that glare cap back on and aim you light correctly so you dont blind people. Hope I helped a little.
