Lamp out light
Old Apr 21, 2006 | 02:05 AM
romic00's Avatar
romic00
Default Lamp out light
Couple of days ago the lamp out light came on. There are no burnt bulbs anywhere. What else should i check? thx
Old Apr 21, 2006 | 01:26 PM
osteodoc08's Avatar
osteodoc08
Default RE: Lamp out light
When the lights get a little corrosion on the terminals (esp. the rear tailights) it can give you a false lamp out reading. Many have taken the bulbs out and cleaned up the contacts with a rubber eraser and then put a little dielectric grease in the socket to cure this.
Old Apr 21, 2006 | 03:32 PM
nos4fuel's Avatar
nos4fuel
have you checked ur tail lights for reverse and also by depressing your brake pedal and checking there?
Old Apr 21, 2006 | 04:12 PM
romic00's Avatar
romic00
yes i check and when i try o remove the tail lights they don't come out. I remove the 2 screwes and i pull on the light realy hard but nothing. if i look inside between the light and the metal body it looks like there is anotehr screw or something holding it in. Any idea how to get to it?
Old Apr 21, 2006 | 04:59 PM
osteodoc08's Avatar
osteodoc08
There are two torx screws on the inside of the tailgate for each tail light lens. Then you gotta pull like a motha to get it out. Do a search, you'll find plenty on taking out the tail lights.
Old Apr 23, 2006 | 05:29 AM
New2Durango's Avatar
New2Durango
Take the 2 screws out and then use a screwdriver and CAREFULLY pry the taillight out. You'll hear a pop and it'll come out...Just be careful not to scratch the paint. The headlights are the same way
Old Apr 23, 2006 | 06:57 AM
Hemi_Dub's Avatar
Hemi_Dub
You should check your high beams too
