2006 Ram 1500 Laramie Exhaust Question?
Old Apr 21, 2006 | 02:40 AM
antsam17's Avatar
antsam17
Default 2006 Ram 1500 Laramie Exhaust Question?
This is my first post so forgive me for bringing up an exhaust question if it seems trivial. I have read many many posts on the exhaust setups on 2004 or later Rams, but can someone please explain to me what looks like 3 mufflers from the cats back?
If I start from the exhaust manifolds on the engine they both come down into cats, then each side comes out, then they both meld together into a Y-Pipe, then into what looks like the first muffler. Then out to a straight pipe, then into what looks a larger cylindrical second muffler in the middle body of the truck, then out over the axle into what looks like a third muffler?
My question is, are all three of these things mufflers? I read on this forum that the last one over the axle is probably the resonator, but why are there two additional mufflers previous to it? I purchased a FM 40 series muffler with dual 2-1/4 pipes because I wanted the dual look out back and a meaner sound and wondering where I should cut the stock exhaust off. I was thinking right after the two sides meld in the Y-pipe before the first muffler? Is that correct?
Any help would be appreciated, and I thank you in advance.
BTW - This is my first truck and I love it
Anthony
Old Apr 21, 2006 | 02:41 AM
HemiMan4451's Avatar
HemiMan4451
Default RE: 2006 Ram 1500 Laramie Exhaust Question?
I may be mistaken, but I think there are two resonators?
Old Apr 21, 2006 | 10:30 AM
antsam17's Avatar
antsam17
So there are two resonators?
Is the muffler the large cylindrical tube in the middle of the truck body and first resonator is right after the Y and the second resonator is just before the tailpipe over the axle?
When I replace the exhaust is it okay to cut the exhaust before the first resonator after the Y?
Old Apr 22, 2006 | 11:06 AM
srenken's Avatar
srenken
You have cat coverter, muffler, and resonator. the resonator is much larger to accomodate the added noise when coming out of MDS.
Old Apr 24, 2006 | 12:01 PM
antsam17's Avatar
antsam17
Got the new dual setup with the FM Super 40 installed on Saturday. All I can say is WOW! It sounds like an old school muscle car and I love it. It sounds just like the flowmaster sound clip on their website. http://www.flowmastermufflers.com
The 2006 stock exhaust has an additional resonator up front right after the Y, then the muffler, then there is another resonator right before it exits on the side. I had the exhaust cut right before the first resonator and then installed the new setup.
"We don't need no stinkin resonators" [sm=icon_rock.gif]
Old Apr 25, 2006 | 12:00 AM
06REDRAM's Avatar
06REDRAM
HOW DOES IT SOUND WHEN THE MDS KICKS IN AT LOW RPMS.
Old Apr 25, 2006 | 11:41 AM
antsam17's Avatar
antsam17
You can definitely tell when the MDS kicks in because it immediately has a lighter tone but in my opinion it doesn't sound bad. It kind of sounds slightly stronger than idle if that makes sense.
Anthony
Old Apr 25, 2006 | 05:19 PM
06REDRAM's Avatar
06REDRAM
MY MAGNA FLOW ONLY WENT UP TO THE FIRST LARGE RESONATOR AFTER THE Y . I SHOULD CHECK INTO HAVING THE LARGE RESONATOR REMOVED. THANK FOR THE INPUT.
TOM
