4.7 litre
Old Apr 21, 2006 | 11:59 PM
bto429's Avatar
bto429
Default 4.7 litre
I seen ya'll talk about the hemis and other engines, buit not a lot about the 04 quad cab 4.7 litre. I own one. Would like to know about progammers and mods chips for this engine
Old Apr 22, 2006 | 12:27 AM
ugotit's Avatar
ugotit
Default RE: 4.7 litre
The superchip is a good programmer for the 4.7 also asp has a underdrive pully .There are all kinds of performance mod's for your truck if you need any help or price checking email us at sales@strippermotorsports.com
Old Apr 23, 2006 | 02:50 AM
Johndcjr1989's Avatar
Johndcjr1989
i havent had any experience with the super chips for the 4.7 but my friend had one and he sent it back because he said he didnt get any horsepower out of it and he said all you could do was change tire sizes and stuff. if anyone has one for the 4.7 and has noticed a difference then let me know cuz i want to buy one
Old Apr 25, 2006 | 01:00 PM
kingaling1986's Avatar
kingaling1986
I have the superchips for the 4.7 and I wouldn't have it any other way. Right now I'm running the program for 87 octane because I can't afford the premium required to run the 91 octane program for performance. When I did run the performance setting ( for about 15,000 miles) the truck would outrun my boyfriend's stock Hemi 2500. It's an automatic and will chirp 2nd if I put the pedal down. Now, even running the 87 program, there's a BIG difference in the response and, most noticably, the shift points. I would reccomend getting at least a good CAI so it's suckin enough air though. Exhaust helps too. Hope this helps!
Old Apr 25, 2006 | 08:33 PM
Johndcjr1989
yes it definantly helps alot im gonna order one as soon as i have the cash for it. thanks alot.
Old Apr 29, 2006 | 03:46 AM
prerunner's Avatar
prerunner
the 04 4.7 does not have a programmer yet. All you have is a jet chip...which i wouldn't advise!!!!
Old Apr 30, 2006 | 03:18 AM
AIR RAM's Avatar
AIR RAM
There are a ton of mods you can do to your 4.7L while you wait for Superchips to come out with a tuner...
I have done just about every mod to the 4.7L except Crank/rods/pistons...Other than that I have done them all!
FAST MAN Heads, FAST MAN 212 cams, Gibson headers, 3" single "Y" murge AFTER the transmission, High Flow 3" CAT, Electric cut out, electric fan, underdrive pulley, 2800 stall, AIR RAM INDUCTION, POWER WIRE, JET STREAM SCOOP, 4.56 gears, 70MM throttle body, Flash in works, SAFC II, Wide band O2,... and the list goes on...
SPEED SAFE, AIR RAM
