engine lights emissions/fuel gauge
Old Apr 24, 2006 | 06:41 PM
TEF's Avatar
TEF
Default engine lights emissions/fuel gauge
I've done a search for this and came up with nothing. I've got an 02' Ram 1500 QC 4.7 with approx 41k miles. I got a p0442 code a couple of months ago. (Emissions leak low volume or something like that). I took it to the dealer and even though I bought the Chrysler extended warranty which is good for nothing they want $90 bucks just to look at it. I took it home. Today at lunch my fuel light came on even though the truck is full, and the gauge hit empty. The overhead console shows dashes in the DTE.
It is now throwing codes:
P0463 Fuel Level Sensor Circuit High Input
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0455 Evaporative Emission Control System Leak Detected (gross leak)
Should I look for a fuse? Is there somewhere I can find the voltages/wiring diagram that should be coming out of the sending unit or charcoal canister?
Any other ideas would be appreciated.
Old Apr 24, 2006 | 07:00 PM
buckw1's Avatar
buckw1
Default RE: engine lights emissions/fuel gauge
Almost sounds like something got at the wires around the fuel tank/vapor cannister. Crawl under and have a look for anything amiss especially the wires and connectors.
Extended warranties are insurance, you still have a deductable and none pay for "checking out the problem" Is your time worth anything? So is the techs/shops.
Now, the dealer "may" apply the diagnostic charge toward the repair if tear down is needed to find the problem or work it into the warranty claim but you have to be willing to pay if it is not possible.
Buck
Old Apr 24, 2006 | 07:02 PM
TEF's Avatar
TEF
I'll check those when I get home... If I get home.
Old Apr 25, 2006 | 12:50 AM
TEF's Avatar
TEF
ok... wires look fine and the 2 new engine codes fixed themselves? [:@] I guess it's a good thing but it will just happen again if I don't fix the problem. Any ideas?
