steering will not lock, ignition will not unlock?
Old Apr 25, 2006 | 05:16 PM
ATX's Avatar
ATX
Default steering will not lock, ignition will not unlock?
I have a 2003 Ram 1500. The past few days i had problems with the steering wheel not locking after i turn the igniton off. WHen I try turring the igniton to start the trucks its locked. Played around with reversing the key, holding the brake in, and turing the wheel left and right..The key did turn backwards once allowing me to play the radio. i then turned it forward and it started..I had this problem happen 5 times and it eventually started after several tries. Now it will not start at all...Ignition is locked and the steering will in unlocked...Does anyone have an idea whats wrong? Is this a common problem and how much should it cost to fix.
Thanks
EDIT:::UPDATE...I just tried starting it again, no luck turning it over. But I did get the steering wheel to lock by turning the wheel very hard to the right..
