metal pieces in rear diff
Old Apr 28, 2006 | 04:30 AM
lemonram04's Avatar
lemonram04
Default metal pieces in rear diff
[b]i had a 2004 dodge 1500 sport with the HEMi,,, the truck had alot of power,, to bad it was in the shop more than i was able to drive it. I live in Clovis NM and i purchased my RAM from BENDER!!! Boy was that a huge mistake. I had my tuck in the shop 17 times and i only owned the truck for 18 months[/b]
the only problem with the new mexico lemon law is it has to be in there 4 times for the same problem within the first year of owning the vehicle. the last 4 times it was in the shop was for the rear end. after they had the truck for 2 1/2 weeks, then 1 1/2 weeks, then another 2 weeks and couldnt correct the problem i couldnt deal with it anymore and traded it in. I had problems with the CRUISE CONTROL twice, once for brake switch the second fort he wiring harnes, WINDOW MOTOR, AIRCONDITIONER compressor went out , it took them two times to verify this problem, BAD FUEL INJECTOR, RATTLING NOISE IN THE DASH, ( 4 TIMES), FRONT END VIBRATION i had it in there 3 times for this and they finally changed the ( RACK AND PINION)< they had to replace the stereo TWICE,,, then they tried to tell me that i wouldnt play burned CD's, (REALLY) well the second one they put in worked just fine,,, also the FUEL GAUGE QUIT WORKING (bad sending unit) ,,and last but not least the rear end. DO NOT BUY DODGE, they did ABSOLUTELY NOTHING to help me out!!!!!!! NEITHER DID the BENDER DEALERSHIP!!!
Old Apr 28, 2006 | 06:20 PM
luvthehemi's Avatar
luvthehemi
Default RE: metal pieces in rear diff
SORRY YOU GOT A PIECE OF ****, BUT NOBODY HERE IS GOING TO BUY YOU A NEW ONE SO SAVE YOUR LONG *** POSTS (SAME POSTS) CAUSE I DON'T THINK ANYONE HERE GIVES A **** ABOUT HOW BAD YOU NEED TO CHANGE YOUR TAMPON, AND PICK A BETTER DEALER IF THEY WONT HELP, AND MOVE IF YOU DONT LIKE THE LOCAL LAWS. WE UNDERSTAND IT'S UPSETTING, BUT 4 TIMES IS PLENTY
Old Apr 28, 2006 | 06:26 PM
osteodoc08's Avatar
osteodoc08
ORIGINAL: luvthehemi
Amen.
