should i be worried about my tranny?
Old Apr 30, 2006 | 10:55 PM
b3nzyme's Avatar
b3nzyme
Default should i be worried about my tranny?
well i dont know if this is normal or what, but ive modded my truck to have more horsepower and all and heres the minor problem:
sometimes (and not all the time) when i shift from park to reverse, reverse to drive, park to drive, or whatever, i feel and hear a knocking-like sound in my tranny and my truck jumps a little bit. I wouldnt even have my foot on the gas, only on the brakes. i would also notice this when i am driving. I could be behind someone going slow (like 25-35 and my truck is idling going at the same exact speed behind it and my foot is not on the gas) when they speed up just a little, my truck does the same bumpish-knocking thing when it starts to accelerate. no i am not giving it hard gas i was just acceleratinga LITTLE bit because if you remember, i was behind a slow person and you know how they are.
is it normal or do i worry WAY TOO MUCH?
thank you
Old Apr 30, 2006 | 10:57 PM
b3nzyme's Avatar
b3nzyme
Default RE: should i be worried about my tranny?
lol and its only a 4.7 so its not like i got 5645654323 horsepower under the hood. [8D]
Old Apr 30, 2006 | 10:59 PM
b3nzyme's Avatar
b3nzyme
oh yea and once again, it only happens -sometimes-...
all in all, might just be shifting too fast in a hurry and dont realize it. oh well
Old Apr 30, 2006 | 11:05 PM
oppie311's Avatar
oppie311
I'm guessing that it is your rear U-joint. I had the same problem with my Jeep, and it was the u-joint.
Old Apr 30, 2006 | 11:07 PM
b3nzyme's Avatar
b3nzyme
i hope i wont be breaking anything will i?
like one day, shifting into a gear and BOOM! i stripped a gear of some sort? [][]
Old Apr 30, 2006 | 11:19 PM
oppie311's Avatar
oppie311
If it is your u-joint, the u-joint will snap before anything else. Just get under the truck and see if it actually is the u-joints, and if it is, just replace it. It should only cost around $15. But if it keeps doing it after, take it to a shop.
Also, do you have a locker in the rear axle? Lockers will make loud bangs and chirps very often for some reason, but it is completely normal. The lockers in my Jeep bang loudly when I shift into drive and the jeep lurches forward a little. It might be the same with you.
But it's not a big deal.
Old May 1, 2006 | 12:02 AM
HemiBuell's Avatar
HemiBuell
How have you added all this power to your truck?
If it's a U-Joint it will happen all of the time. At least everytime I have had a bad u-joint in a vehicle it happens all of the time. It will also knock a bit when you take your foot off the gas. Get under there, grab your drive shaft and shake it around hard. If it moves or knocks it is the u-joint.
How is your tranny fluid level? Do you change it?
