Saw Nick, got the PW!
Old May 3, 2006 | 08:13 PM
tamuccmike's Avatar
tamuccmike
Default Saw Nick, got the PW!
$30....awesome...Nick was a pleasure to do business with and even installed it and helped me reset the PCM...very customer oriented and great to talk to...the PW is awesome, you can feel it working! Thanks man!!!
Old May 4, 2006 | 02:38 AM
AIR RAM's Avatar
AIR RAM
Default RE: Saw Nick, got the PW!
Im glad you like it... Now try to drive with a light foot and let that POWER WIRE save you some gas... You should see 1-2MPG increase if you can keep your foot out of it.
SPEED SAFE, AIR RAM
Old May 4, 2006 | 11:32 PM
tamuccmike's Avatar
tamuccmike
HAHAHAHA!!! yeah right! you know how hard that has been for me since i've had it? I will TRY though...especially after i get those cutouts installed tomorrow...hmm thanks man
Old May 5, 2006 | 01:38 AM
SilverBullet0205's Avatar
SilverBullet0205
same here, saw nick earlier this week and he installed it for me. great guy, definately plan on getting his intake! and saw a gas miliage increase of about 1.5-2 immediately! great mod, highly recomended!
Old May 5, 2006 | 04:25 PM
dRam2500CT's Avatar
dRam2500CT
Can somone explain to me what this PW (power wire?) is/does?
Old May 7, 2006 | 02:06 AM
AIR RAM's Avatar
AIR RAM
ORIGINAL: dRam2500CT
The POWER WIRE is a "PLUG & PLAY" Intake Air Temperature Mod, this means NO wires to cut. The POWER WIRE can be found on www.AIRRAM.com .. It will tell your PCM that the actual Intake Air Temps are a FIXED 20 degress cooler than actual Intake Air temps "AT ALL TIMES" .. so no matter what the intake air temps are, subtract 20 degrees and thats what your PCM will read when the PW is installed.
What does this do? This causes the PCM to ADVANCE the timing which in turns makes more power. Back in the day, one way to make more power on a carburated engine was to advance the timing... because our modern engines do NOT have a distributor we need to trick the PCM to do the timing advance for us. The POWER WIRE is set up so your PCM will NOT know its there and there for will NOT adjust and counter the effects. The Average gain is 10RWHP and most people see 1-2MPG increase after installing the POWER WIRE on there 3rd Gen Ram (under a light foot).
Here is a PICTURE of the "POWER WIRE" & AIT MOD wire:
Above you see the POWER WIRE and the AIT MOD wire... The AIT MOD wire is somthing new I have been working on and can be used to fit your own resistor or POT resistor (Adjustable) in line... so there are NO wires to cut.
The POWER WIRE is below it and is a direct "PLUG & PLAY" mod.
Old May 7, 2006 | 11:18 PM
dRam2500CT's Avatar
dRam2500CT
I see.
But wouldn't the truck think the engine is running colder than it should therefore puts out more gas trying to warm it up?
Old May 8, 2006 | 01:39 AM
AIR RAM's Avatar
AIR RAM
I see.
NO, the PW does NOT alter the engine temp reading... It is altering the Intake Air Temp reading. The intention of the PW is to get the timing advance and under a light foot this timing advance will make more power with less throttle and there for you can get better fuel economey. On average customers report 1+MPG when driveing steady speeds on the highway.
At WOT the PW will add approximately 2% more fuel... but thats at WOT... So if your looking for better fuel economey then you really should not be at WOT anyways... but that additional 2% more fuel does help make the additional advertised 10HP .
If you have any additional questions please feel free to contact me.
SPEED SAFE, AIR RAM
Old May 8, 2006 | 08:20 PM
dRam2500CT's Avatar
dRam2500CT
Gotcha, thanks.
Old May 9, 2006 | 12:12 AM
AIR RAM's Avatar
AIR RAM
No problem, if you have any additional questions please feel free to contact me.
SPEED SAFE, AIR RAM
