Changing differential fluds
Old May 16, 2006 | 11:08 PM
hmipwrd's Avatar
hmipwrd
Default Changing differential fluds
I'm assuming there are probably a few people that changed there own diff and t-case fluid on there rams, I'm just looking for some advice on whats best to use (I like royal purple), I hear in the tranny to only use the mopar stuff. does the diff cover use a gasket or a sealer (my jeep just used a rtv? sealer as the gasket) and is there anything/problems i might run into doing this myself. thanks in advance.
Old May 16, 2006 | 11:41 PM
osteodoc08's Avatar
osteodoc08
Default RE: Changing differential fluds
The 1500 models have synthetic from the factory (rear). LSD requires the friction modifier on 1500 models also. The covers are sealed with RTV.
Old May 17, 2006 | 12:49 AM
mazz's Avatar
mazz
I changed the fluid in both differentials on my '04 with Amsoil Severe Gear. Used RTV to seal the covers on. I also used Amsoil Universal ATF for the transmission. Just changed everything at 60k. The transmission was rather time consuming and fairly messy, but worth it. Also used Amsoil ATF in the transfer case. Transmission is running about 20 degrees cooler, and the transmission shifts so much smoother. DC says you "have to" use ATF+4, but so many have changed over to the Amsoil ATF with great results.
Old May 17, 2006 | 03:26 PM
hmipwrd's Avatar
hmipwrd
thanks for the replies, how do I know if my truck has LSD or not? also will i need a add any additive w/ royakl purple or amsoil, also what weight is recommended (isnt something like 80-90) again thanks in advance.
Old May 17, 2006 | 04:45 PM
osteodoc08's Avatar
osteodoc08
Take a look in the glove box, it will have the gear ratio and whether it is a LSD or not.
Old May 18, 2006 | 03:26 AM
berg501's Avatar
berg501
Amsoil Severe Gear 75-90 gear oil is recomended for the Limited Slip Differential. It already has the needed additive in it, per the Amsoil Tech guy I spoke with last week. I will be changing mine this weekend, along with the engine oil & filter.
Mike
