Rear End noise 2002 Ram 1500
Old May 23, 2006 | 12:18 PM
AIR RAM's Avatar
AIR RAM
Default RE: Rear End noise 2002 Ram 1500
Im sorry... I ment after they broke! Those pictures above are what I found at the botton of my housing... They tend to BRAKE on the 9.25 rears quite often.
If there where no bits and peices after you changed your fluid then you are fine. Did you add the right "friction addditive"... you need to use the stuff Dodge sells. It may make things quiet again.
SPEED SAFE, AIR RAM
Old Dec 11, 2010 | 09:34 PM
JonnyBlaze420's Avatar
JonnyBlaze420
Hmmm, I'll have to check mine. If the clips are broken I can just replace?
Old Dec 13, 2010 | 12:16 PM
Greg in MO's Avatar
Greg in MO
If you are getting vibration as you accelerate, then it could also be a bad u-joint. Fortunately, they aren't too bad to replace.
Greg
Old Dec 13, 2010 | 06:06 PM
JonnyBlaze420
Mine was from the new ceramic rear brakes pads apparently.
