Installing New Shocks on Your Own
Old May 25, 2006 | 10:46 AM
enash's Avatar
enash
Default Installing New Shocks on Your Own
Has anyone on here installed new shocks on their own? Is it difficult to do or should I take it to shop?
Old May 25, 2006 | 01:02 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Installing New Shocks on Your Own
Well that depends on how mechanical you are. If you take your truck in to get the oil changed, then no I would not do it.
If you are the kind of person who does the oil you should be able to handle this job. Helps if you have a hydraulic jack, and air impact tools.
Did you put on all your aftermarket parts??
Old May 25, 2006 | 02:40 PM
osteodoc08's Avatar
osteodoc08
Personally, I think it is very easy as it is just swapping out parts. For the front there are 3 bolt each shock, might be only two bolts per shock on the front for you 4x4 guys, and for the back, there are 2 each shock. It can be a pain sometimes if it is set up like it is on a Ford in the rear, but were talking about Dodge the Dodge is really easy to swap shocks on.
Old May 25, 2006 | 05:35 PM
enash's Avatar
enash
Thanks for the feedback. The only aftermarket item I didn't do myself was the catback.
Old May 25, 2006 | 06:13 PM
osteodoc08's Avatar
osteodoc08
ORIGINAL: enash
In that case, you'll be good to go. Just take your time and follow the torque specs. Other than that, the biggest headache is deciding on a shock. Know which ones you'll go with yet?
