Problem with idle
Old May 26, 2006 | 05:59 PM
hawkster2's Avatar
hawkster2
Default Problem with idle
My truck when first starting it revs to around 2500 rpms and then will drop to about 1200 rpms. The idle will jump from 1200 to 750 rpms until I give it some gas and then everthing will be fine. Any body have any ideas to what the problem might be.
Old May 26, 2006 | 08:09 PM
Gone Fishin's Avatar
Gone Fishin
Default RE: Problem with idle
May need a good throttle body and injector cleaning
Old May 29, 2006 | 06:47 PM
lesclifton's Avatar
lesclifton
I have a 2004 and mine did a very similar thing. It started all of a sudden, and did it for awhile. I took it in as it was under warranty and they said it was bad gas. I always fill up in the same place using chevron, so I didnt believe it. They drained the tank and cleaned it and it has ran great ever since. I hope this helps, I am glad it was nothing more serious, even though this was a hassle enough.
Old May 29, 2006 | 11:14 PM
hockeynut52's Avatar
hockeynut52
May be time to change the plugs buddy.
Old May 29, 2006 | 11:55 PM
osteodoc08's Avatar
osteodoc08
Change plugs, clean the TB, and get good gas. That should take care of it.
